It is currently Sat Aug 02, 2025 11:54 pm
PostPosted: Fri Jan 11, 2019 9:46 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I do not know where I went wrong. I had a guitar body that had suffered a lot of damage at the hands of it's owner. They asked me to repair. I should have said no. I removed the neck, sanded to wood. Repaired damage. Seal coated. Z-poxy. Sanded, then wash coat in zpoxy. Looked great. Sprayed with Enduro-Var. after three coats, I level sanded to remove orange peel. Then sprayed a bunch more coats. Let set for a week, level sand. Each time I've done then, I end up with thin layers higher than surrounding area. Like plateaus. Lets just say the surface is not level. Why? Where is that effect coming from? Is my early level sanding causing this? I realize you will want pictures. I will try.
PostPosted: Fri Jan 11, 2019 9:56 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Here is a pic. You can see areas of shine and dull.
PostPosted: Fri Jan 11, 2019 10:40 am
Last Name: Beaver
City: Lake Forest
I'm guessing it has to do with the original finish/porefill on the wood. I think I remember you have used the seal/epoxy/Enduro-Var procedure before with success. My only other thought is did you use a different sand paper than before? Water based can be temperamental. Or maybe the owner used a silicone polish on it that somehow survived the sand to bare wood.
So... no real help here
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jan 11, 2019 11:39 am
First name: Larry
Last Name: Hawes
Curious Mike, you write "Seal coated. Z-poxy." I have never seal coated under Z-Poxy and not sure why one would/should. What was that seal coat? Why?
Curious is all, as my help and experience is limited but have applied EnduroVaor over ZPoxy over bare wood with no problems other than normal bone head user errors that just sand out.
Keep us updated please.
Thank You and Best To All
PostPosted: Fri Jan 11, 2019 12:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Sealer is two part, keeps oils from spreading. It is an adhesion promoter as well.
PostPosted: Fri Jan 11, 2019 12:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Joe, I have no idea. I'm tossing Enduro. Going to do this one in nitro and figure out my next step for finishing future bodies.
PostPosted: Fri Jan 11, 2019 12:40 pm
First name: Larry
Last Name: Hawes
Thanks Mike, have you used it on this wood type before? Would you mind sharing a couple details about the 2 part product? Like what it is? Curious for a couple reasons, one there might be others that might want to use it in the future, and second just wondering if this wood type (which is what?) behave a little differently with this 2 part sealer.
And again probably not helping much, but have never heard of using a sealer under Z-Poxy but I have a lot to learn.
PostPosted: Fri Jan 11, 2019 2:15 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.simteccoatings.com/MSDS.ivnu
58x1 and 58x2
Product works fine. One component has a limited shelf life. Spray it on. I have used it before on this wood. No problems
PostPosted: Fri Jan 11, 2019 2:28 pm
First name: Brad
Last Name: Combs
Mike, what grit are you leveling with?
PostPosted: Fri Jan 11, 2019 2:32 pm
First name: Larry
Last Name: Hawes
58x1 and 58x2
Thanks for taking the time to post the info. One last question...what wood? [:Y:]
PostPosted: Fri Jan 11, 2019 5:16 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
cocobolo
PostPosted: Fri Jan 11, 2019 5:51 pm
First name: Larry
Last Name: Hawes
THX
PostPosted: Fri Jan 11, 2019 6:14 pm
Last Name: Beaver
City: Lake Forest
Mike, I know what you mean. I was a KTM user for many years. When they sold out I decided to go with Cardinal LuthierLac. I like it a lot, but being a nitro it has some drawbacks. I plan to try Royal-lac post-catalyzed on my next build. It is a prototype for a new way of building, at least for me. I did some test panels with the stuff over various pore fills a couple years ago. So far none of the crazing and checking problems others have reported.
I am always looking for the perfect finish. What I really want to try is a two part urethane, Maybe latter this year.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jan 11, 2019 6:51 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
What do u mean by two part urethane? Something catalyzed? Me personally, I'm done with water borne products. I think I will research some higher end products. I never had issues with Enduro until recently.
PostPosted: Fri Jan 11, 2019 7:12 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Could the seal coat be incompatible with Enduro-Var? It looks very similar to a lacquer touch-up where the surface is not prepped for burn-in, so I would suspect adhesion issues where the layers did not tie together. Enduro-Var will chemically bond if recoated within an hour or so, but if not recoated in 2 hours, the surface needs to be sanded.
We don't use Enduro-var over anything but raw wood or 3M Silvertip Fast. I assume you are dry-sanding, as wet sanding even well-cured Enduro-var can result in varying levels of witness lines.
We dumped Z-Poxy for epoxy fill work a few years ago, both because of the bleed issues and downstream separation problems with lacquer topcoats. This may be related to the amine blush issue which Z-Poxy has, and reaction between higher pH salts and lower pH (~ 5.5-6 perspiration. Maas, System 3 Silvertip, and West 105/209 are blush and bloom free. Also, Z-Poxy goes more intensely amber as it ages, so can be a pain to touch up on a sand-through.
- Beth Brower
PostPosted: Sat Jan 12, 2019 2:12 am
Last Name: Beaver
City: Lake Forest
Mike,
The urethane finish I am most interested in trying is Deltron from PPG. It is an automotive finish that Brian Howard used on guitars before he went to the UV cured stuff. I haven't got it figured out yet but, I think he used the DCU2021 urethane and the DCX61 hardener. He did say any pore fill that works with solvent finishes should work fine. You will also need to seal with a vinyl sealer after the fill. He recommended a Mohawk product but I don't know which one.
The pieces I am missing is a paint schedule, along with a sanding and buffing schedule.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: edstrummer (Sat Jan 12, 2019 5:29 am)
PostPosted: Sat Jan 12, 2019 7:48 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Yes, PPG DCU2021 Concept clear is a very good choice. This is a complete chemical cured finish and will harden to rubber inside a gun if not cleaned fairly promptly . Also requires accurate chemistry for mixing.
Brian
PostPosted: Sat Jan 12, 2019 2:44 pm
Last Name: Beaver
City: Lake Forest
Brian,
Hardening inside the gun is one of my concerns. How many coats, and time between coats are you able to spray before the leftover product has to be dumped and the equipment cleaned?
Joe Beaver
Maker of Sawdust
